Thanks Tom,
That worked out perfectly, although I had to
change the Bit# to 153. :)
Is there a list of the Bit #s for the Kanalog
terminals?
I looked and couldn't find it.
Although I still would have had to ask you for
the code even if I did know which # related to
which terminal.
Thanks again - Ross
On 16/09/2011 2:15 PM, Tom Kerekes wrote:
Hi Ross,
That should be IO # 154
SetBit(154); // Kanalog FET
Driver 2
Delay_sec(2);
ClearBit(154);
fermanz <ferman@...>
To:
DynoMotion@yahoogroups.com
Sent:
Thursday, September 15, 2011 5:17 PM
Subject:
[DynoMotion] Bedway Oiling during
Homing
Since we fitted shielded ribbon
cable to JP6 I have had no more
handwheel encoder problems.
We are on to some more fine
tuning and need to change the
saddle oiling system, which has
been hooked up to activate when
the spindle runs.
It is tending to over oil the
bedways.
I would like to run it with the
Homing sequence and see if that
will give sufficient oil for the
way we operate the machine.
I can't figure out how the SW
numbers relate to Bit #s
I have the saddle oil pump relay
connected to SW2 on JP8.
I need to activate it in
Homing.c
How should I do that please.
A snippet of code to paste in
would be nice. :)
Ross
Ferguson Windmills Company
835 Old North Road,
R.D.2, Waimauku,
New Zealand. 0882
Ph 64 9 411 8332 Mobile 027 282 7689
Fax 64 9 412 8655
E-mail - ferman@...
http://www.windmills.co.nz
